I'm trying to learn how to use GordianKnot to convert .vob files into a 2 CD Xvid set. I'm on step 2 of the guide on doom9 and I'm at the compressibility test part. When I click "Now" to run it, it runs but it doesn't make the changes to the "Bits/(Pixel*Frame)" dialog frame. When I click "Save & Encode" in the preview window like it says later in the guide, the job comes up and the video is there but it still requests the audio source file in the Audio 1 tab in the job file but the guide said it should be filled in for me.
The only hint I have something is awry is that in the Log window in the Encoder tab in GK, it says:
However in the bitrate tab, in the Audio A frame it has a good bitrate set and in the "Interleaving & AVI-Overhead" frame, I chose "1x vbr-mp3". The same happens when I have "1x ac3/cbr mp3". Can a knowledgeable GK user shed some light on something I missed cause I'm still learning?Code:<time>: Audio 1, disabled, no recalc. - you probably want to add this track later <time>: Audio 1, calc: 124648kb
Results 1 to 1 of 1
Please guide to BRRip
By RoTeMaN in forum Blu-ray RippingReplies: 2Last Post: 19th Aug 2010, 00:28 -
A simple question on Two passes Xvid Encoding,using GordianKnot(not autoGk)
By avengerevenge in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2010, 07:46 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 20:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 22:34
