  1. I use to use InstantCopy or DVD2DVDR for all my backups. However, I ran in to problmes with Metallica - Cunning Stunts. This movie is big, about 8gb.
    So if I decide to use Instantcopy I have to convert main movie to around 55% so that's no alternative, because the quality sucks at 55%.
    DVD2VDVR let you pick only one angle to keep. So if I keep angle 1, it's only 4,2 GB and that would be fine. But here come the next problem. I allways keep the main menu and extra, therefor I have to left 950mb in the MB reserved box, but this option is not avaible because the movie need no encoding if you only keep one angel.
    So I need a program that let me keep menues and give me decent quality. I don't care if I only keep 1 angle. So anyone have a tips?
    Mar 2003
    Uranus
    Yeh , Get rid of the menu
  3. Well, I allways keep the menues and especially for this movie, get rid of the menues is no alternative......
  4. try with clone dvd 2, theres a trial version fully functional for a month. Just uncheck the angles you don want, and made a custom dvd of 6 or 7 gb. Then open the resulting files with dvdshrink, and compress.
