Hi,
how to make DVD with subtitles (3 or 4 of them) using DVD-Lab? I don;t see any options for doing it at all, but maybe there is some way to do it.
Milan
It is isn't possible(you can use ifoedit to add the subs and then use dvd-lab, https://www.videohelp.com/forum/viewtopic.php?p=863473#863473). The next beta version of DVD-lab Pro will support it.
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 15:12 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 09:14 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
