on my PC, but i need a software that reads 3 drives. Currently i am using nero easy cd/dvd creator and that only reads 2 drives.
Any suggestions on a software that enables my computer to read 3 drives for burning.
Results 1 to 14 of 14
please do not double post !
Originally Posted by bart9
6. Does Nero Support writing to more than one recorder at a time?
Yes. For how to use this feature in Nero refer to this link to a step by step PDF file: http://www.nero.com/en/index.html#c1034060180057
With OEM versions you can only write to one recorder.
With Nero Demo and Retail versions, you can write to two
recorders.
For additional recorder support you must purchase an upgrade to a new Serial Key to support additional drives. Cost of the upgrade is listed below:
Multiple Recorder Support
1. Nero support max. 7 recorders simultaneous price 249,00 USD
2. Nero support unlimited recorders simultaneous price 499,00 USD
( Note: We have test 24 recorders simultaneously to date, and simply have not had the system to test more.) -
Bart9 Says ... I have 2 burners and 1 dvd player
Lacywest says ... thats nice
Bart9 then asks me ...
"what type of software do you use lacywest to run two burners and 1 dvd player?"
Sorry ... I'm being a dick ... just a tinge ... I did have a CD burner but I removed it and installed the Toshiba instead ... I needed it to read DVD-RAM disks.
Back to the subject ... can a external USB DVD Burner ... be detected -
the nero software costs 300 dollars that enables you to burn with more than one burner, who is gonna pay that much just so i can read one more burner????????????????????/
Standard nero will support 2 burners, if you want more then you need to buy the more expenive version, or look into discjuggler like I mentioned earlier.
i have standard nero and it does not support 2 burners, and 1 dvd player. it only supports 2 drives total. if you read my earlier message, nero's only software that supports 7 dvds or burners costs close to 300 dollars, so thats not what i am looking for.
Also the other thing your recommended discjuggler , i downloaded a demo, that does not support 2 burners, so your info is not correct. -
and the demo DJ also burnt CD's at 1X...full functioning software probably supports 3 drives, as DJ tends to be really barebones on the demos they supply.
Also you quoted
the nero software costs 300 dollars that enables you to burn with more than one burner, who is gonna pay that much just so i can read one more burner -
what version nero do you have that allows you to burn with 2 dvd burners and 1 player, meaning, using 3 drives all at the same time.
i contact nero tech support, and they said the only software that they have that can do that is the professional nero called Nero max. 7 & 32 recorders - and this thing costs close to 300 dollars.
currently i am using nero easy cd and dvd creator 6 and it only supports 2 drives. -
I said that nero could burn to 2 drives after you quoted it could burn to just 1
the nero software costs 300 dollars that enables you to burn with more than one burner -
Why not just pay for the software that will do what you want?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 17:01 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 18:27 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 21:53 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 15:18
