I am not sure if the information I recieved about Win xp is correct or not, from a so called friend. Maybe someone who has XP can enlighten me.
He says: 1. It dose'nt have a startup disk
and that you can't create one.
2. When he tried to do a clean Install
on a formatted blank drive after typing in
Setup, this is what came up "This programme
cannot be run in Dos mode".
Is he winding me up or is it true? I was always under the impression it was only when you had an upgrade you could'nt run Setup. Could it be he has a bootleg copy?
Regards: Patsym1
1>You can have a boot disk: put a blank disk in your floppy drive, use Windows Explorer, click on a: (wutever)right click choose Format and choose make boot disk.
2>Make sure he's running from the installation CD-ROM not the drive he wants to install WindowsXP on.
Unfortunately making a boot disk like you say ember dose'nt give him access to his cd-rom drive?
Regards: Patsym1 -
you can make a startup disk, but i prefer using the win98 boot disk. about your 2nd point, i figure your friend used a boot disk, formatted, and then wanted to install. just like when installing win2k from dos/98startup, you can't just run setup.exe, you have to run winnt.exe from the i386 folder.
<font size=-1>[ This Message was edited by: kriskim on 2001-11-06 19:51:02 ]</font> -
Or boot from your CD-Rom drive. That works as well as using the winnt.exe file
You can install using winnt.exe from the i386 folder, but if you dont install smrtdrv.exe it will take hours.
Best way is to boot from cdrom.
Remember we are talking about the win NT kernel not the win 9x kernel. -
<font size=-1>[ This Message was edited by: cazatom on 2001-11-09 03:34:58 ]</font>
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win TV USB
By Trollheart in forum Capturing and VCRReplies: 0Last Post: 18th Oct 2009, 05:25 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
Win Tv Nexus-s
By hartless in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 03:07 -
Upgrade to Win XP
By CSULB71 in forum ComputerReplies: 19Last Post: 20th Feb 2008, 10:59
