i see a lot of dvd players on the compatibility chart that says they can play divx....how do u burn a divx movie? do u use normal discs or do u use dvd burner and dvd discs?
Massimo N. Aldorasi
Most DivX (AVI) files that you come across are small enough to fit on a standard CD-R (700mb or less). You just burn them in standard ISO format and they will play on a DivX standalone player e.g. LiteOn LVD-2001 or LVD-2002. You can also burn them on a DVD-R the same way, just fit more of them since the disc capacity is larger.
Ethernet (n): something used to catch the etherbunny
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
