i have been using TMPGEnc plus to encode and TMPGEnc authur my DivX files to DVDs - not sure what happened, but TMPEnc will no longer work on my pc - it acts like it's encoding however the end results are just blank.... i have uninstalled and reinstalled - used a reg cleaner between installs - everything short of a reformat which i really do not want to do.....is there another program that works as well (hopefully as easy) and perhaps a guide to give me the step by step procedures on getting these files to a dvd? thanks in advance.
you sure its not a codec problem with the file you're trying to convert?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
dang if that wasnt the problem!!!!!! it's working now!!!! thank you very much conquest10 i'm happy again!!!
Remove WGA 1.2 doesnt work
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 7th Mar 2009, 00:46 -
Videos don't work anymore
By SINZAR in forum Software PlayingReplies: 5Last Post: 14th Mar 2008, 13:46 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
Member Status......doesnt work
By electricsguy in forum FeedbackReplies: 14Last Post: 25th Jun 2007, 11:21 -
Futureshop doesnt sell Verbatium DL discs anymore?
By MeekloBraca in forum MediaReplies: 6Last Post: 1st Jun 2007, 11:36
