I already have a DVD authoring software (Pinnacle Studio). I burned my personnal home DVD from a DV camcorder for archival purposes. But this software does not support VOB files as source. I am searching for an inexpensive software that could help me convert my personnal DVD back to an .MPG or .AVI file without quality loss so I could use it as a source in my authoring software back again. I am looking for a fast one click solution that would produce a single 5GB file containing both video and audio streams from my DVD disk. I don't want something that would re-encode my video, resulting in quality loss (like DivX or such). I don't want something that would produce 2 separate files that I have to sync back together (like some demux programs). I seem to be the only one in the world to have that need, as I am talking about personnal (non-commercial, unprotected, region-free) DVD. My authoring software only accepts .MPG or .AVI files as input, so how can I restore my DVDs back to this format, simply and quickly?
Any help appreciated, thanks!
Womble mpeg video wizard, it's the only tool I know that accepts vob's and outputs mpegs with no re-encoding of the video.
Vobedit will demux a vob into individual streams that any authoring program that's worth it's salt should accept. If your authoring program only accepts multiplexed mpegs then it's time to find another one. Demultiplex/multiplex should not cause any sync loss."Art is making something out of nothing and selling it." - Frank Zappa -
Check Smartripper, I believe that I used it to get MPEG files from VOB files (standalone DVD recordings). Maybe DVDDecrypter can do it too. Of cource not re-encodig is involved.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Thanks for the mpeg video wizard link. It really did exactly what I asked for and produced a single .MPEG file from my DVD (pretty fast). But for a reson I don't undersand, Studio 8 has some problem with it (black screen and no sound). I will file a support request with Pinnacle on this topic.
About the demux topic, I don't know what to do with .M2V files. Studio 8 does not support them. I like Studio 8 because I am able to edit, author and generate my custom DVD titles for a 1 hour video in less than 20 minutes. Then I press "Burn DVD" and few hours later, it is ready. Kids love it. I realize now that input formats is a limitation. What authoring program would you suggest as a Studio replacement?Originally Posted by ZippyP.
Originally Posted by ZippyP. -
I tried Smartripper but it looks that this tool is only to unprotect commercial DVD as it outputs another VOB file. Maybe I did not figure out how to change output to .MPEG. Same thing for DVDDecrypter.
But I will surely take some time to read your topic on Studio 8 very soon...
Originally Posted by donpedro -
DVDDecrypter, IFO Mode, Stream Processing, Snable Stream Processing, Click on Video and Audio stream separately and select Demux option.
Not sure if that is what you are looking for... I believe that same can be done with Smart ripper. In my test I have got separate m2v file (mpeg2 video) and ac3 file (AC3 sound from standalone DVD Recorder).
BTW: Did you try to rename VOB file to mpg ?
What type of light source are you using in your home?
By johns0 in forum PollsReplies: 15Last Post: 9th Dec 2011, 12:33 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 23:59 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 21:03 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48 -
back to square one. cdr source questions.
By Dr.Gee in forum MediaReplies: 2Last Post: 5th Jun 2007, 18:03
