I already have the TDK, but it's unopened and I can return it easily. And I wouldn't mind if Maxell is a better brand. But if they are the same quality I will just stick with TDK even though the price per unit is slightly higher. My TDK package does say "made in Taiwan"
Any help is appreciated,
Thanks,
Todd
They could be the same disc-- both TDK and Maxell have used RICOHJPNR discs in the past, although TDK lately is going to CMC a lot. If you have a spindle of CMC TDK's, the Maxells are a *much* better deal.
Unfortunately, without opening the spindle, I don't know how you tell. You might want to return them and get the Maxell just to be safe. -
either way i say maxell cause you know what the hell your getting.
Get the Maxell for $27 at Office Depot. The deal ends Saturday (tomorrow). Mine are definitely RicohJPN.
LRD -
Generally speaking, Maxells are good discs. I've never used their DVD+R discs but LRD has reported them to be RICOHJPN. That's a good formula.
The Memorex +R discs I use are RICOH and they do fine. -
I have an older cake of Memorex RicohJPN DVD+R 4x. I bought 2 new 50 cakes from Office Depot 2-3 weeks ago, and they were CMC MAG with a write ID speed of 2.4x. I had some problems burning them with my TDK 420N. Memorex allegedly is sending replacement media. Be careful. They came in a tall cake with a large white spacer. The shorter cake with no spacer is RicohJPN.Originally Posted by indolikaa
LRD -
They are most likely both RICOHJPN ... maybe TDK has CMC ... so ask yourself, who's pretty stamp on the top do you like better? Maxell or TDK? That's all it comes down to now, that and price.
Maxell DVD+R
By biged670 in forum MediaReplies: 5Last Post: 2nd Jul 2009, 13:52 -
Best Buy Verbatim - 50-Pack 16x DVD-R Disc Spindle $12.99
By sknox in forum MediaReplies: 5Last Post: 16th Mar 2008, 21:46 -
Maxell and TDK made in Taiwan
By xSimonx in forum MediaReplies: 1Last Post: 15th Oct 2007, 21:58 -
Maxell DVD's surface color
By sknox in forum MediaReplies: 5Last Post: 27th Aug 2007, 22:26 -
Watermark like spots on Maxell DVD +R ?
By Belles Toaster in forum MediaReplies: 4Last Post: 25th Jul 2007, 21:02
