  1. is it possible to burn a movie from your PC and then watch it on ur laptop then get a tv-output wire thinggy and view it on your TV as well? while connected to laptop?...
  2. Possibly.
    It could depend on if the 'thingy' is an S-Video or composite (RCA) video cable coming out of the laptop or a VGA converter box.
    EDIT: Comments duly noted, tweedle.
  3. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    It could depend on if the 'thingy' is a video cable coming out of the laptop
    I don't understand this technical stuff.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Anything's possible (just about).
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes you can do it. We have done it before with our laptop hooked up to a projector - we just used a data to data cable from the monitor port. For a TV you might need a data to RCA cable or if you have a separate video out, a S-Video to RCA or RCA to RCA plug.
    If in doubt, Google it.
  6. Member nexus123's Avatar
    Feb 2004
    Check out ebay theres a guy on there selling pc cards for laptops that has video out to hook to your tv with a multicable that has rca outs and s video they usually go for around 14.99 the cards he sells though only work on win 98/2000 not xp I was going to buy one till I realized my Ibm thinkpad w/ a pentium 166 82megs of ram doesn't handle divx well and I would end up having to convert my movies anyway which was the reason I wanted to use the laptop was to cut out the conversion process
    "We were in barstow on the edge of the desert when the drugs began to take hold."
    Dec 2002
    My Swamp
    Buying a standalone player is probably better and cheaper than buying the 'Thinggys' you may need for connecting a laptop to your TV.
    Q. With TV out on any computer , don't you just get Video to your TV ?
    You've then got to do something about audio. You wouldn't really want to watch the picture on a tv and get possibly poor sound from your computer.
    It's just a thought.
  8. Member nexus123's Avatar
    Feb 2004
    If you've got a sound card all you would have to is either cut/splice a male headphone or pc/speaker connector w/ a rca cable or buy what I believe is called a mini connector/rca cable adapter to run it from your line out of the lap top to your audio in either on the tv or dvd/vcr I think the whole point of him wanting to play the movies from his laptop is to save the time of having to convert his movies to something a stand alone dvd player can handle which I don't blame him I'd check around with office max and other places and see if they carry a vga to tv card for your laptop I wish I could do this but like I said divx plays jerky on my laptop. Ne-ways good luck wit ya. P.S. if your laptop doesn't have a line out chances are it has a head phone jack which would prob. work just as well.
