When recording onto dvd-r is there a way to create chapters without having to Stop recording and start again when you want a seperate chapter?
a N00B![]()
I have an E50 and if there is a way I'm not aware of it. However, I've only had it for a couple months and I'm still discovering cool stuff it'll do.
I think there was a selection in the manual for doing that but no one figured out how to use it.
I'm sure there's a setting to automatically set chapters every X minutes. I use one at work so I don't have the manual handy. Look it up.
"Art is making something out of nothing and selling it." - Frank Zappa -
Anybody figured out how to use the manual yet?Originally Posted by handyguy
The answer really depends on how you are planning to use the recorded DVD-R discs. You can easily add any chapter points to the un-finalized DVD-R discs by using the "Marker" button, but once the disc is FINALIZED, all the chapter points created earlier would disappear and instead, a five-minute chapter break is automatically added to the DVD-R disc. Of course you can add chapter points to DVD-RAM discs the same way and won't lose them since there is no finalization required.Originally Posted by kentu3
So if you are planning to finalize the recorded DVD-R discs and play them in other players, then stop and start again seems to be your only choice. If you use a recorder with an HDD such as E80H or 85H, then you'll be able to preserve the chapter points using the high speed dub.
Recording satelite TV with Panasonic DMR EH59
By bjuice in forum DVD & Blu-ray RecordersReplies: 20Last Post: 3rd Sep 2012, 19:22 -
Panasonic DMR-EH57, recording problem
By Recordering in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Sep 2010, 17:39 -
Best setup for recording on Panasonic DMR-75EX
By mister_to_you in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Jun 2008, 06:57 -
Panasonic DMR E80H problem when recording..
By Gravelexpress in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th May 2008, 10:36 -
Panasonic DMR-ES10 No recording
By TAMMU in forum DVD & Blu-ray RecordersReplies: 12Last Post: 22nd May 2008, 23:52
