    Nov 2001
    canada
    hey i was just wonderin why do most of the vcd's i burn dont work on my vcd player. the other thing is that when i put them in a dvd player it shows and instead it being full screen its a small little screen in the corner of my tv, i followed your instructions but it turns out this way can you help me out thanxs.
  2. More details, please.
    How did you encode, author, and burn your VCDs (software, etc.)
    What VCD and DVD players are you using?
    Nov 2001
    canada
    well i used the tmpgenc to convert my avi. to mpeg. first then i use vcdimagergui to make the bin and cue files then i burn it using CDRWIN. the vcd player i use is moon a player from china and the dvd player is a pioneer.
