I'm not sure if this is because I'm using the demo, and can't encode to mpeg-2 with the demo, or if I am doing something wrong, but the menu seems to work fine while in 'Edit' mode. I can select any chapter and it will go to that scene but after I go to 'make movie' and 'create'AVI' file, the menu just plays like any other scene when I convert to mpeg-2 using TMPGEnc and then burn to DVD. There is no clickable menu at all. The menu I make is there, but just as a scene and I can't select any chapters.
Since I can't encode to MPEG-2 with the demo, I decided to try to burn a VCD. Everyting seemed to burn fine, but when I played the VCD in my DVD player, the menus didn't work. It showed the 4 chapters I made, but it was just like every other part of the video. I couldn't click on the menu items to select different chapters.
While in Studio 0, and I select 'make movie', if I select the little DVD button over in the far bottom right of the preview window, the menus/chapters work just fine. They work exactly as I would like them do when I burn to disc.
Does it not work because it is the demo?
Will Pinnacle Studio9+ work with Windows 7???
By rrtbusa in forum Capturing and VCRReplies: 0Last Post: 14th Dec 2009, 18:06 -
Do HD-BURN CD made with Nero work in DVD Players...
By Ensign in forum Authoring (DVD)Replies: 5Last Post: 11th Sep 2009, 22:43 -
Rip a strange work made DVD
By jntaylor63 in forum DVD RippingReplies: 5Last Post: 22nd May 2009, 05:45 -
Film Don't Work On DVD Player...
By Chana1 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Jul 2007, 16:25 -
Dvd's don't work after a while.
By FreeDiver in forum DVD & Blu-ray WritersReplies: 15Last Post: 11th May 2007, 00:46
