guys, im looking for some ideas on good movie editing software. i have the adaptec a2310 dvd media center for capturing TV etc. I want to add special effects, what software does this....i.e a bolt of light (like a laser) being fired, this kinds stuff, but basic.....ideas and thought appreciated Gordon.
AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights -
Premier will do all that and more. It is not easy to learn, but if you're a fast learner and have a good imagination, then that is the S\W you want.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
if you want a software that is more stable , more features , and easier to learn than premiere, (plus much better audio support)- look at using Sony Vegas ..
but for want you want to do -- Sony Screenblast might be a better choice .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanku racer and BJM. I will look into the both of them. Thanks for ur advice...Gordon
don't get me wrong -- premiere is a good app also --
hey BJ_M, i got premier 6.0. im going to have a go at that over the weekend. thx for ur replys, appreciated...gordon JJ
i would upgrade 6.0 to 6.5 asap ....
thx for the advice there, so update to 6.5 i will....thx for all ur help..Gordon TJ
[Q] good audio editor
By Csubakka in forum AudioReplies: 4Last Post: 27th Nov 2010, 10:28 -
Can anyone recommend a good AVI editor?
By djdust in forum Newbie / General discussionsReplies: 48Last Post: 17th May 2010, 13:46 -
Good editor? (Freeware)
By chronic777 in forum EditingReplies: 10Last Post: 23rd Jul 2008, 14:22 -
Can Anyone Recommend a Good Audio and Video Tag Editor?
By Nitro89 in forum ComputerReplies: 1Last Post: 23rd May 2008, 02:16 -
Paint.NET is a very good free image editor!
By racer-x in forum ComputerReplies: 1Last Post: 19th Feb 2008, 12:51
