I used TMPGEnc before in cutting my SVCDs,it ran good but at end of SVCD1 there's always an extra video like for 5 seconds without an audio.
I tried using bbMPEG V1.2, wowwwww!!! it's accurate without any problem...
I'd like to mention that TMPGEnc works perfectly in cutting VCDs.
Cheer up guys!!!
Here's a guide to do this. This will solve your problem cutting SVCDs using TMPGEnc.
http://www.vcdhelp.com/bbmpegedit.htm
Cheer up guys!! -
Are you sure you don't have any problem with SVCDs that've been cut with bbMPEG while playing on standalone? Have you tried to use "Goto" or "RW/FF" with those svcds?
I still have out of sync problem with my SVCDs those've been cut with bbMPEG. What is your process to do so? I'd like to try to solve my problem. -
This the link where you can find "how to", http://www.vcdhelp.com/bbmpegedit.htm
but if you want bbMPEG to cut your SVCDs into two automatically use this:
on your "Program Stream Setting is SVCD
General Setting - Start Second is 0, End second is write more than the total time of your movie and Max Size (MB) write not more than 790 mb, and check all these three: Reset clocks, Set Broken Link Flag in GOP and
VCD Cutter
By devilcoelhodog in forum EditingReplies: 0Last Post: 16th Jan 2010, 15:39 -
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 15:06 -
a video cutter
By Benygh in forum EditingReplies: 5Last Post: 3rd Nov 2009, 15:55 -
MKV Cutter ??
By RVD2720 in forum Video ConversionReplies: 2Last Post: 13th Mar 2009, 18:45 -
Looking for Mpeg2 Cutter
By 557953 in forum EditingReplies: 6Last Post: 8th Sep 2008, 22:56
