I was trying convert a video file and svcd2dvd will just stop at this step. Here is the highlights of the log:
******** Multipexing elementry streams
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [mplex] File E:\wt.b_FIXED_DVD.mpv unrecogniseable!
INFO: [mplex] File E:\wt.b_FIXED_DVD.mpa looks like an MPEG Audio stream.
**ERROR: [mplex] Unrecogniseable file(s)... exiting.
System.IO.IOException: The process cannot access the file "E:\wt.b_FIXED_DVD.mpv" because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.File.Delete(String path)
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
What can I do to fix this problem?
It seems something is wrong when multieplexing the source file. But with this info i can't see what.
Greatings,
Yf -
Here is the whole log:
Starting SVCD2DVD: v1.51.2.0
Begin time: 5:45:41 PM
******** Ripping BIN images to get mpegs (VCDGear )
Analysing File: E:\wt.b_FIXED.mpg
++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
-->Processing 1 mpeg files
############### New MPEG File ###############
Type: VCD
Horizontal Res: 352
Standard: NTSC
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 345MB, Duration: 00:01:32, Rate(MB/Min): 224.85)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 55MB, Duration: 00:00:37, Rate(MB/Min): 88.41)
******** Trimming start of video ES
I hope somebody can tell me what can I do to fix my problem or what other software can I use. -
Can you have a look at:
https://www.videohelp.com/forum/viewtopic.php?p=866741#866741
It solved it in this case.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
3 movies, 6 elementary streams, 1 DVD
By Pholder in forum Authoring (DVD)Replies: 1Last Post: 5th Aug 2010, 08:51 -
Multiplexer for elementary streams for a BD-R / AVCHD
By BobaFett77 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Jun 2010, 16:59 -
demux a .mp4 to elementary streams
By halsboss in forum Video ConversionReplies: 4Last Post: 28th Nov 2009, 16:38 -
How do you join elementary streams?
By rayden54 in forum EditingReplies: 0Last Post: 5th Jan 2008, 20:43 -
From DVD VOBs to proper elementary streams
By gabier in forum Video ConversionReplies: 9Last Post: 28th Nov 2007, 21:48
