Camcorder has "DV In/Out Analog Input"-- is 1394 IEEE compatible.
The instruction manual doesn't even mention how to transfer DV to PC, only still photos. The camcorder has a DV out connection on it.
When I transfer MiniDV tape tp my computer using DV cable, will I still only be able to capture in realtime? In other words, I will have to "play" the tape in the camcorder, while I capture it into my PC? If this is true, what is the benefit of MiniDV, other than a better picture? I thought DV meant that the video was saved on the tape as a file that could just be tranferred to the PC using a firewire, sort of like how a Digital camera's compact flash creates a new drive letter on your computer.
Tom Simmons
There is a big difference between the recording mediums of Compactflash and MiniDV. Compactflash cards can read any single part of it's stored memory almost instantaneously. MiniDV on the other hand is a tape, which records the information magnetically (just like any other tape medium), but instead of analogue information, it records it digitally, as 0s and 1s (in basically dvd quality). The reason for using tape for video, is that it can store lots and lots of information; more than any other format, and is cheap to manufacture.
To answer your question, recording from a tape medium to another medium (eg minidv to computer) requires it to be played at 1x, for maximum quality. The heads that pick up the magnetic 0s and 1s need time to sense them. You will need special software to transfer it. Check out https://www.videohelp.com/capture.
Need JVC SR-S365U Instruction or Service Manual
By jbd5010 in forum Capturing and VCRReplies: 4Last Post: 1st Jun 2011, 19:41 -
JVC miniDV video capture on a pc ?
By silverclaws in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2009, 06:55 -
jvc sucks!!!
By Marvingj in forum Newbie / General discussionsReplies: 5Last Post: 2nd Aug 2008, 10:36 -
Anyone with user manual to jvc dr m70
By ajah in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 17:47 -
JVC GY-DV301: Focus manual
By B-Twien Bytes in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2007, 07:53
