Like the title says, when I encode a film with TMPGEnc the final result is a lot darker than the original file. Its as if someone has messed with the brightness on your tv.
Any ideas?
Cheers!
How long is the movie you are encoding? What format are you encoding to? I had these same problems when encoding large DVD Movie files over 2 hours in length. The preview window is a good indicator of what you are getting. So you could adjust the brigthness/contrast in TMPGENC to your desired results.
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Hmmm...not sure as to why you have this problem. go into the settings of TMPGENC and click on the "Advanced" tab. Double click on "Simple Color Correction" and adjust accordingly. You may want to frameserve with virtual dub I dont know if that will help or not.
A darker picture is one of the known issues with the default settings of TMPGenc. The solution, as the previous poster remarked, is to get into SETTINGS -> ADVANCED -> SIMPLE COLOR CORRECTION -> BRIGHTNESS, GAMMA and possibly CONTRAST.
Different MPEG-2 encoders have different default settings for things like gamma and contrast. TMPG's default settings make the picture look too contrasty and dark for my taste; YMMV. MainConcept's default settings seem to make the MPEG-2 output look a lot more like the input. CCE's defaults seem to make the picture look too contrasty. Adjust to taste.
SOLVED: Media Player Classic - playback picture too dark......
By bahjan in forum Software PlayingReplies: 0Last Post: 17th Nov 2010, 06:32 -
HDV Picture is too dark.
By dj_magic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Jun 2008, 15:21 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 21:52 -
How to improve dark VHS picture?
By rbatty11 in forum RestorationReplies: 15Last Post: 11th Sep 2007, 19:57 -
Dark picture
By MarioB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Aug 2007, 00:14
