  1. I have an ADVC-100 and Premiere Pro that I am using to capture old VHS Tapes. My understanding is that the ADVC-100 has a built in codec that converts the analog video signal to a digital avi file. The video quality of the digital file is determined by the canopus codec in the ADVC. Premiere captures the digital file and saves it a a type 2 avi file. So in fact the capture software should have no effect on the digital file other that the avi type. Now when I render or export avi with Premiere what codec is Premiere using? I have two choices, Microsoft avi or Microsoft DV avi. When I export to mpg I would guess it is using the main Concept codec.
    From what I have read in the DVDrhelp forums, for which I am so thankfull for your help, the Microsoft codec's are not tht great. I did read that canopus has come out with a codec to be used in Premiere. Is this a codec I should use? I have not seen it on either web site so I am not sure if it is out yet. thanks Jim
    Nov 2000
    GLoucester
    Really it depends on what you want to do with the file.
    If you want to export it back to your camera it needs to be DV AVI.
    If you want to export it to DVD then use the Adobe Media encoder and select Mainconcept.
    Hope this helps.
    TOMMO
    Apr 2002
    Oskeeweewee Ontario
    That depends on your Export setting. I'm sure you're using DV NTSC, so in that regards, the next thing would be to check if your settings carry the Canopus codec. If it does, use it.
    http://www.microsoft.com/whdc/hwdev/tech/stream/vidcap/dvavi.mspx
    You should get the program avic to look at the codec. I get a codec of dvsd when I use premiere. CCE does not like this so I have the canopus codec installed and I use avic to change the fourcc from dvsc to cdvc and most programs like this better.
  5. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Actually, Premiere Pro uses the Main Concept DV Codec, it does not use the MS DV Codec. If you export the AVI to DV AVI, it will be Main Concept codec that is used.
    * Previous versions of Premiere use the MS DV Codec.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    racer is 100% correct ..... its a modified version of the main Concept dv codec and its pretty good
  7. Thanks for all the responses. I am a little confused as to why the main concept codec is call Microsoft DV AVI. Does anyone know where I could get the Canopus codec to compare it to the main concept one?
  8. Hi jimby452,
    Simply go to http://www.canopus.com/US/support2/support_index.asp
    this link register your product and get the updated & new drivers specially
    made for Premier Pro.
    I am sure your problem get solved. Regarding DV Codec, If you captured using
    Canopus DV Codec use the same for best result & compatibilty. Using
    any other codec might cause in QualityLoss .
    Regards.
    JUST EDIT & PLAY.................apnait.com
