Hi, I have a problem with DVD Shrink 3.1, there is a NTSC film which i wish to make region free using this program but every time i try and load the disc into the program a error comes up and so stops me.
'Failed to open file "D:\Video_TS\VTS_01_5.VOB"
The system cannot find the file specified'
Does anyone know what this means & why it is doing this, and how to overcome this problem. Many thanks in advance.
If it is laready another region code and y0our reader if not set to that region it won't even open it. Use AnyDVD running in the background and will render your DVD drive as region free and all disk as unprotected. Unless there is actually something wrong with your ntsc files themselves, it ought to work. I run dvdshrink / anydvd and I've been able to do anything with it. Is this an actual disk or from another source? Can you play it on your computer??
No DVD can withstand the power of DVDShrink along with AnyDVD!
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Will using the pc while using DVD shrink cause problems to editing????
By jones24 in forum DVD RippingReplies: 8Last Post: 7th Oct 2008, 10:39 -
problems with DVD Shrink 3.2.0.15
By janefield in forum Newbie / General discussionsReplies: 6Last Post: 25th Aug 2008, 07:20 -
dvd shrink problems
By anahata3 in forum DVD & Blu-ray WritersReplies: 9Last Post: 9th Jul 2007, 11:07
