Is there software that will convert a regular DVD placed in your DVD ROM drive and convert the whole DVD to MPEG4 with Dolby Digital 5.1??
#1 DVD Ripper looks cool but it looks like it does not include Dolby 5.1 in the rip....only 2 channel.. http://www.dvdtox.com/dvd_ripper.htm
Results 1 to 11 of 11
Originally Posted by teegee420
There's a difference between asking for help about something you genuinely don't understand and choosing not to even try to find the answer yourself. Sorry, just a pet peeve of mine I guess.
Originally Posted by Daveyd
OK, everything else aside...For those of you that have used this program, can you answer my question? -
It is free to download...and use..
A good question is "Should I downsample my 5.1 Audio to 2.0 to save space if I'm shooting for a 2 CDR DivX".
A bad question starts with "What is the Best...". There is no best, it varies with your IQ, computer horsepower, learning ability, and skillset.
For me, I'd use VDUBMOD, DVDDecryptor and AVI MUX to make a DVD into an MPEG4 with AC5.1 Audio. The other tools work just fine, but I don't need up front GUI's to do it all for me. Some are 'better' than others, in that you need to know practically nothing in order to use them.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
There is a Flash demo on the site that show some of the resolutions.
have a look
I want to conver a file to FLV format. with audio aac and video as mpeg4/h2
By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 02:45 -
convert XviD to DVD format but lost audio track 2
By zenghe in forum Video ConversionReplies: 2Last Post: 3rd Mar 2009, 16:34 -
How do you convert the video format from MPEG-layer 3 to MPEG4 SP?
By Conconn in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 05:32 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54 -
Dual Audio .OGM format to MPEG4
By Van Klizzy in forum Video ConversionReplies: 4Last Post: 29th Jun 2007, 23:50
