After analyzing phase finishs, the program freezes during the checking status. I cannot figure out the problem.
Assuming not system or hardware problems, it is almost always atributed to a fault with your original disk. It may even play perfectly well in your player but playing and analizing / ripping is another story. Wash it gently in some soapy water, rinse well and dry with a perfectly lintless cloth from the center out. Not in a circular motion. If that doen't help, try a diferent disk. If that works, then it's the disk.
You can always try to rip with a diferent prog like DVD decrypter but more than likely it will not work. I've had several disks act that way for me as well. Very annoying!No DVD can withstand the power of DVDShrink along with AnyDVD!
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
DVD Shrink disc freezes in Win Movie Player
By visionman in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2010, 08:12 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
