  1. Can somebody help.I have 2 dvdr installed fine and copy disk to disks(2) with alcohol120 but when ive tried with nero it makes me pick which burner to write to.I've highlighted the box "use multiple recorders" but it then gives a choice of on or the other.
    Can anybody help?.
    Thanks in advance.
  2. Choose recorders while holding down the Ctrl button.
  3. Thanks for the quick reply jben01 works a treat thanks.
  4. I've tried this on the new nero 6 and it just brings up the box to select which recorder to use ??
  5. That was the same as mine fatbloke but if you read the reply from jben01 it worked for me.
