no doubt the solution is staring me in the face but right now i cant see it.
im shooting video on a daily basis which includes some long panning shots,
i capture footage to fce,export as QT(DV-Pal)and drag into toast to burn at 1 speed,high quality.
When i watch on TV,during the panning shots,the edges,lines and patterns of any objects in the shot flicker/shake really bad.
Is this to do with interlacing?i dont have a clue.
Thanks in advance for any advice
luke
sorted it out now,
i deinterlace entire edit before exporting from final cut,no more stutters.
only problem is it takes ages to render,about 2+ hours for a 15 minute movie,so if anyone else reading this knows a faster way please let me know. -
It sounds like the field dominance is wrong.
Have you tried to do this with the latest versions of apps and have you checked the settings (if the user can set these things)?
DV and consumer DVD/MPEG is bottom field first (I just learned that professional DVD apparently uses top field first).
In my experience many early version applications set the field dominance wrong.
Xbox 360 1080p MP4 Playback Issue - Video Flicker/Tear
By kfrye89 in forum Newbie / General discussionsReplies: 8Last Post: 11th Jun 2011, 17:35 -
Why DVD playback is jerky when panning?
By videdit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Nov 2010, 12:10 -
Capturing from VHS to divX: Recommendations (Flicker & freezing proble
By roylayer in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2008, 17:00 -
newbie,i have a problem,i burn a dvd on playback i get stutter when panning
By goldenbhoy in forum Newbie / General discussionsReplies: 10Last Post: 28th Apr 2008, 14:00 -
Jerky action shots or panning motion
By dadrab in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:58
