  1. I tryed to convert a divx to VCD with ffmpegX 0.0.9b
    I used the preset -VCD-
    It use the mpeg1 (mpeg2enc).
    I add a subtitle file. And I have 2 errors when launching the encoding :
    **ERROR: [mpeg2enc] pel_aspect_ratio must be between 1 and 14 (MPEG-1)
    **ERROR: [mplex] Unable to open file /private/var/root/Desktop/Movie/movie.mpv for reading.
    I tryed the preset with SVCD and it works without problem.
    If someone know the problem.
    Thanks.
    And FfmpegX Is really a great app !!!
  2. Tryed again with 0.0.9c. Problem persist
    It occurs only when I use 'enocding with Player' cause I have to burn some subtitles on it.
    Encoding started on Wed Apr 7 21:58:00 CEST 2004
    -f 2 -b 1150 -B 260 -V 46 -a 2
    -F 1
    INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
    INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
    INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
    Using GNU internationalization
    Original domain: messages
    Original dirname: /usr/local/share/locale
    Current domain: mplayer
    Current dirname: /usr/local/share/locale
    MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    : No such file or directory
    can't open '/var/root/.mplayer/codecs.conf': No such file or directory
    can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
    AltiVec found
    Reading config file /usr/local/etc/mplayer/mplayer.confReading config file /var/root/.mplayer/config
    Reading /var/root/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
    CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/private/var/root/Desktop/Stargate.avi' '-aid' '1' '-sub' '/private/var/root/Desktop/Stargate.srt'
    get_path('font/font.desc') -> '/var/root/.mplayer/font/font.desc'
    Can't open input config file /var/root/.mplayer/input.conf : No such file or directory
    Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
    Falling back on default (hardcoded) input config
    ile: /var/root/.mplayer/font/font.desc
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Using Unoptimized OnScreenDisplay
    Using usleep() timing
    Terminal type `unknown' is not defined.
    get_path('input.conf') -> '/var/root/.mplayer/input.conf'
    get_path('Stargate.avi.conf') -> '/var/root/.mplayer/Stargate.avi.conf'
    Playing /private/var/root/Desktop/Stargate.avi
    Not an URL!
    File size is 735940608 bytes
    AVI file format detected.
    list_end=0x2286
    ======= AVI Header =======
    us/frame: 41708 (fps=23.976)
    max bytes/sec: 0
    padding: 0
    MainAVIHeader.dwFlags: (272) HAS_INDEX IS_INTERLEAVED
    frames total: 139469 initial: 0
    streams: 2
    Suggested BufferSize: 0
    Size: 640 x 360
    list_end=0x10F4
    ==> Found video stream: 0
    ======= STREAM Header =======
    Type: sdiv FCC: 3vid (33766964)
    Flags: 0
    Priority: 0 Language: 0
    InitialFrames: 0
    Rate: 23976023/1000000 = 23.976
    Start: 0 Len: 139469
    Suggested BufferSize: 53040
    Quality 10000
    Sample size: 0
    found 'bih', 40 bytes of 40
    ======= VIDEO Format ======
    biSize 40
    biWidth 640
    biHeight 360
    biPlanes 1
    biBitCount 24
    biCompression 861292868='3VID'
    biSizeImage 691200
    Regenerating keyframe table for DIVX 3 video
    list_end=0x217A
    ==> Found audio stream: 1
    Type: sdua FCC: (0)
    Flags: 0
    InitialFrames: 1
    Rate: 24000/1 = 24000.000
    Start: 0 Len: 139607353
    Suggested BufferSize: 3840
    Quality -1
    Sample size: 1
    found 'wf', 18 bytes of 18
    ======= WAVE Format =======
    Format Tag: 8192 (0x2000)
    Channels: 2
    Samplerate: 48000
    avg byte/sec: 24000
    Block align: 1
    bits/sample: 0
    cbSize: 18
    Unknown extra header dump: [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0]
    list_end=0x2286
    list_end=0x22E2
    hdr=Name size=1
    Name :
    hdr=Subject size=1
    Subject :
    hdr=Artist size=9
    Artist : heroofmm
    hdr=Copyright size=1
    Copyright :
    hdr=Comments size=1
    Comments :
    hdr=Software size=13
    Software : Nandub v0.22
    Broken chunk? chunksize=1302 (id=KNUJ)
    list_end=0x2BB29C66
    Found movie at 0x280C - 0x2BB29C66
    Reading INDEX block, 175826 chunks for 139469 frames (fpos=0x0)
    AVI index offset: 0x2808 (movi=0x280C idx0=0x4 idx1=0xF0C)
    Auto-selected AVI audio ID = 1
    Auto-selected AVI video ID = 0
    AVI: Searching for audio stream (id:1)
    AVI video size=592031697 (139469) audio size=139607353 (139607353)
    VIDEO: [3VID] 640x360 24bpp 23.98 fps 814.2 kbps (99.4 kbyte/s)
    [V] filefmt:3 fourcc:0x33564944 size:640x360 fps:23.98 ftime:=0.0417
    Clip info:
    Name:
    Subject:
    Artist: heroofmm
    Copyright:
    Comments:
    Software: Nandub v0.22
    SUB: Detected subtitle file format: subviewer
    Using AltiVec optimized IMDCT transform
    SUB: Read 871 subtitles.
    Opening audio decoder: [liba52] AC3 decoding with liba52
    dec_audio: Allocating 3840 bytes for input buffer
    dec_audio: Allocating 6144 + 65536 = 71680 bytes for output buffer
    AC3: 2.0 (dolby) 48000 Hz 192.0 kbit/s
    A52 flags before a52_frame: 0x2A
    A52 flags after a52_frame: 0xA
    AUDIO: 48000 Hz, 2 ch, 16 bit (0x20), ratio: 24000->192000 (192.0 kbit)
    Selected audio codec: [a52] afm:liba52 (AC3-liba52)
    No accelerated resampler found
    vo_yuv4mpeg: Using (default) progressive frame mode
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    INFO: libavcodec init OK!
    Selected video codec: [ffdivx] vfm:ffmpeg (FFmpeg DivX (MS MPEG-4 v3))
    Checking audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
    [libaf] Adding filter dummy
    [dummy] Was reinitialized, rate=48000Hz, nch = 2, format = 0x00000000 and bps = 2
    AF_pre: af format: 2 bps, 2 ch, 48000 hz, big endian signed int
    AF_pre: 48000Hz 2ch Signed 16-bit (Big-Endian)
    PCM: File: audiodump.wav (WAVE)
    PCM: Samplerate: 48000Hz Channels: Stereo Format Signed 16-bit (Little-Endian)
    PCM: Info: fastest dumping is achieved with -vc null -vo null
    PCM: Info: to write WAVE files use -waveheader (default); for RAW PCM -nowaveheader.
    AO: [pcm] 48000Hz 2ch Signed 16-bit (Little-Endian) (2 bps)
    AO: Description: RAW PCM/WAVE file writer audio output
    AO: Author: Atmosfear
    Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
    [libaf] Adding filter format
    [format] Changing sample format from 16bit big endian signed int to 16bit little endian signed int
    Starting playback...
    XXX initial v_pts=0.000 a_pos=3840 (0.160)
    [libaf] Reallocating memory in module format, old len = 0, new len = 65540
    [ffmpeg] aspect_ratio: 0.000000
    VDec: vo config request - 640 x 360 (preferred csp: Planar YV12)
    Trying filter chain: vo
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is undefined - no prescaling applied.
    VO Config (640x360->640x360,flags=0,'MPlayer',0x32315659)
    INFO: [yuvscaler] VCD output format requested in NTSC norm
    640x360 Planar YV12
    VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
    VO: Author: Robert Kesterson <robertk@robertk.com>
    *** [vo] Allocating (slices) mp_image_t, 640x368x12bpp YUV planar, 353280 bytes
    INFO: [yuvscaler] input: frame size: 640x360 pixels (345600 bytes)
    INFO: [yuvscaler] input: frame rate: 2997003/125000 fps (~23.976024)
    INFO: [yuvscaler] input: interlace: none/progressive
    INFO: [yuvscaler] input: sample aspect ratio: ?
    INFO: [yuvscaler] from 640x360, take 640x360+0+0, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] scale to 352x180, 352x240 being displayed, NOT_INTERLACED/PROGRESSIVE
    INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
    r] without line switching
    INFO: [yuvscaler] without time forwarding
    INFO: [yuvscaler] Without luminance correction
    INFO: [yuvscaler] Without chrominance correction
    INFO: [yuvscaler] black lines: 30 above and 30 under
    INFO: [yuvscaler] black columns: 0 left and 0 right
    INFO: [yuvscaler] frame rate: 23.976 fps
    INFO: [yuvscaler] Scaling ratio for width is 20 to 11
    INFO: [yuvscaler] and is 2 to 1 for height
    INFO: [yuvscaler] Specific downscaling routing number 3
    output: frame size: 352x240 pixels (126720 bytes)
    INFO: [yuvscaler] output: frame rate: 2997003/125000 fps (~23.976024)
    INFO: [yuvscaler] output: interlace: none/progressive
    INFO: [yuvscaler] output: sample aspect ratio: ?
    INFO: [mpeg2enc] Selecting VCD output profile
    INFO: [mpeg2enc] Encoding MPEG-1 video to /private/var/root/Desktop/Stargate01.mpv
    INFO: [mpeg2enc] Horizontal size: 352 pel
    INFO: [mpeg2enc] Vertical size: 240 pel
    wait, encoding to mp2 audio with mp2enc...
    = UNDEFINED: illegal aspect ratio code
    INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
    INFO: [mpeg2enc] Bitrate: 1150 KBit/s
    INFO: [mpeg2enc] Field order for input: none/progressive
    INFO: [mpeg2enc] New Sequence every 780 Mbytes
    INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
    INFO: [mpeg2enc] Search radius: 16
    INFO: [mpeg2enc] GOP SIZE RANGE 12 TO 12
    INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
    INFO: [mpeg2enc] Progressive format frames = 1
    /Applications/ffmpegX.app//Contents/Resources/mencvcdX: line 216: 813 Broken pipe $command
    ++ WARN: File length according data tag: 2147479596
    ++ WARN: File length according RIFF tag: 2751459336
    ++ WARN: Inconsistency is inevitable if wav's are being piped
    INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
    INFO: format = 0x1, audio length = 2147479552 bytes
    INFO: slots/frame = 731
    INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
    INFO: Fractional number of slots, padding required
    INFO: System is big endian
    INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
    INFO: Encoding with psychoacoustic model 2 is finished
    INFO: The MPEG encoded output file name is "/private/var/root/Desktop/Stargate01.mpa"
    INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    **ERROR: [mplex] Unable to open file /private/var/root/Desktop/Stargate01.mpv for reading.
