Its my first time using this forum.
I have an xvid file, that I want to convert to VCD, using TMPGEnec and virtualdub. I want to add subs using virtualdub.
This is my file:
--> {XviD MPEG-4 Codec}, 5 channels stereo.
Audio Format:
Code: 0x2000
Vendor: Dolby Laboratories, Inc
I have all codecs needed installed!! I have also installed the handler to virtualdub.
first I tried to make a wav fil using virtualdub:
No audio decompressor could be found to decompress the source audio format.
Then I used Goldwave to make the audio file, and thats fine, now I have a separat audio file.
But when I try to framserv whit virtualdub, I load the vdr file into TMPGEnec, it says it is unsupported or can not open. I have tried the correct the TMPGEnec settings, VFAPI plug ins, but it doesnīt help. I have search this forum but cant find any guides.
Somewhere I read that I need to install the AC3 decompressor into virtualdub, but I dont know how! I have downloaded this AC3 decpompressor, and installede it, but cant choose it in virtualdub?
Under Audio, compression I cant find anywhere to choose the ac3???
Help needend, if you understand my problem. THANKS
I feel for you here - I have a come across a few files that I cannot frameserve from vdub to TMPGenc, but they open fine in TMPGenc. Not figured it out yet so I can only suggest you create a new avi with subs using vdub and load the new avi into TMPGenc.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
You tell me to load the movie into virtualdub, add my subbs, and then save new avi??
It still tell me that audio decompressor could not be found. I need help installing the ac3 decompressor into virtualdub.
Thanks -
I want to get this option??
https://www.videohelp.com/toolsimages/standardtool372.jpg -
don H
After you install the ac3 acm decompressor you need to close vdub and open it again. Click audio>full processing mode and then audio>compression. The decompressor should appear in the window. When you tried to frameserve to TMPG did you choose the wav file created by goldwave as the audio to be used in vdub? -
don H
Itīs funny, it dosnt appear under audio,compression! I have tried to install it again, but with same result
No, I didnīt choose the wav file from goldwave when I tried to frameserv...normmaly I add the wav file in TPMG. -
Since you have a seperate audio file you don't need to frameserve the audio. Before starting the frameserver go to Audio and select No Audio, then frameserve. It might work.
"Art is making something out of nothing and selling it." - Frank Zappa -
Hi.
I saved a new avi file, adding subs with virtualdub. Saved it without any audio, and then started TPMG, added the audio file which I made with goldwave. It turned out well. Now I have an VCD with subs and everything.
Thanks for helping you guys!
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 16:47 -
Need help can't convert .mp4 file to xvid using VirtualDub
By s_joy09 in forum Video ConversionReplies: 12Last Post: 19th Jul 2011, 06:52 -
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 17:05 -
WMV to Avi(xvid,mp3) using VirtualDub - huge destination file
By chm in forum Newbie / General discussionsReplies: 9Last Post: 20th May 2010, 18:29 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50
