Results 1 to 12 of 12
  1. Hello,
    What is the best version of DVD Shrink when comparing quality. I want to use the one that will give me the best quality. I am currently using 3.1.7.6 and i am getting really poor quality since i started to use this version. So what is the best version for quality??
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use 2.3 and 3.1.4b and both produce EXELLENT quality. Try here:
    http://www.dvdshrink.info/guides.php
  3. why is the latest produce bad quality compare to old ones ? it is not suppose to be the other way around ?
  4. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    I use the latest and feel the quality is excellent.
  5. Banned
    Oct 2003
    Pearl Harbor USA
    Well, DVDShrink works for Nero on Recode now. I remember DVDToolBox 1.6 was great until the author sold it to DVDFab, then he released the last DVDToolBox 1.7 which was a total crap.
    I don't imply DVDShrink does the same trick here. I get great results from all pre-3.1.76 versions of DVDShrink, but I have not tried 3.1.7.6 yet.
    Just a few cent from senior citizen.
  6. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I use 3.0
    Jul 2003
    michigan
    as far as quality, i don't think there's any difference. they all use the same encoding method. The difference between versions is just extra features, and bug fixes
    Dec 2002
    I've never had a wquality issue with Shrink, ever, any version since 3.0.5b . The only time I've seen a quality issue is when some tries the impossible (50% or lower). I mean come on, you want to take a full DVD9 and put in on a DVD5 with no quality loss? Don't you think the studio would have done that if they were able in the first place to save money? It can't be done so stop trying. Ether do without extras/menus or deal with macroblocks.
    I'm sure LOTR3 will be one of those, that was a long-ass movie with a lot of action and dark scenes. Dances with Wolves Director's cut was a true DVD18, so Shrink stands no chance by itself (although the 2 disk backup was pretty good). Both are a 2 DVDR backup unless I transcode to 1/2D1. I've seen DVD Video that was 2 GB to 8 GB when ripped. Shrink just isn't right for some movies.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  9. Never had a problem with 3.13
  10. Member GKar's Avatar
    Jul 2003
    In the corner, on a stool
    Unfortunately 3.1.7 was giving me some pixelization during scene transitions so I went back to 3 beta 5 which seems to work for me.
  11. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I've used most if not all of the versions and am currently using 3.1.7.5. Seems to be working as well or better as previous versions.
    Feb 2004
    WI.
    I'm using 3.1.7.6 and it works good for me. I'm not seeing any of the blurriness or pixelation everyone's talking about?
