Hi, I have a small problem. I have dl some AVI's and also some SVCD's so that I can convert them. But some of them seem to "jump" every now and then as if they are missing a frame each time. Every thing else is fine, nice sharp picture and good audio. What is causing this and how can I cure it? GSpot says I have all the right codecs for each file.
I just started trying to investigate and understand possible causes for this. In a recent thread about a similar problem Lordsmurf remarked that it sounded like an interlace/deinterlace issue. Search "jumpy avi" and you'll find it. Or maybe it was "jerky avi".
I solved my problem by simply running the file through VirtualDub in full processing mode after editing, and recompressing with different codecs. No idea -yet- why it smoothed everything out. VDub did complain about corrupt header when the file was first loaded and proceeded to rebuild it. You might try a short clip and see. That is, unless and until you get a more informed response.
BTW, the very first thing to do is scan for errors. VirtualDub-MPEG2 was the version.
Pull! Bang! Darn! -
right I just dl another AVI and the same thing, I'd say it is every 30 seconds or so and it looks like it is pausing for half a second. I am scanning for errors with the video in full processing mode. but I dont think it will show anything. Could you give me any pointers for procedures in Virtual Dub as I'm a bit of a novice.
HELP! ASAP! Conversion .VOB to .AVI videos are jumpy!
By AngelVideo in forum Video ConversionReplies: 4Last Post: 20th May 2011, 19:36 -
Avi to dvd jumpy..?
By Mozzy31 in forum Authoring (DVD)Replies: 7Last Post: 7th Feb 2010, 05:05 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
DVD to AVI file Jerky Jumpy
By Dolfin the Mammal in forum DVD RippingReplies: 8Last Post: 21st Aug 2007, 11:47 -
jumpy windows media player - avi
By bufalo in forum Software PlayingReplies: 3Last Post: 27th Jul 2007, 15:07
