Hi there, I recently bougth a new hard disk 160 GB for storage use for capturing and editing videos. I already have a 40 GB disk (primary master) running winXP, and a dvd writer (secondary master).
Which one of the following is the best connection for the new disk![]()
a) As primary slave
b) as secondary master and dvd writer secondary slave?
stpapaf
I would go with primary slave. Keep the slower devices on a separate chain.
keep hard disks on one cable and optical disks on a seperate cable. This is becuase all disks on one cable will default to the slowest speed of any device on that cable.
Uh, I don't think that's entirely trueOriginally Posted by RabidDog
Used to be true years ago but not anymore. Modern chipsets adjust for the speed of individual devices on each channel.keep hard disks on one cable and optical disks on a seperate cable. This is becuase all disks on one cable will default to the slowest speed of any device on that cable.
To answer stpapaf's question (with an opinion). For disk to disk editing and Shrinking / re-encoding of large files, it would be better to have your new hard drive on the opposite channel thatn your C: drive. Rip to Primary, Re-encode or edit to Secondary (master or slave doesn't matter). Since that is typically the longer operation you will save the most time. Even if your not ripping but just capturing it would benefit you to capture to one channel and burn to the other.
I would put the new drive as a Secondary Master and move your burner over to Primary as a Slave. -
Thanks a lot all of you.
Finaly, I decided cabling the second storage HDD as primary slave and to leave the dvd burner alone in the second channel as secondary master.
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
adding subtitles to BLURAY disk!
By smounche in forum Authoring (Blu-ray)Replies: 2Last Post: 15th Oct 2009, 04:38 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32 -
Adding a menu to a dual-movie disk
By WHeisenberg in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2008, 14:29
