i have a laptop with windows 2000 pro, however i do not have the restore disk to this laptop, i was wondering what my best option would be of the two below
1. use the windows backup utility. (would this save the Win OS, all files and programs so that if i made a restoration it would restore all back to its previous state?)
2. make the expense to purchase norton ghost or similar program (would i be able to save it to a usb drive then take that image i created and copy it to cd from another computer? and does it save the winOS and programs currently on the harddrive?)
what i'm look for is to create my own system restore cd or disk. any help is greatly appreciated and thank you all in advance for your suggestions or comments
thanks
Ghost makes a bootable image of your drive on cd-r or dvd-r. When your computer messes up just pop the cd or dvd. It will boot up like a windows cd and it will install your saved image. Very nice program.
i dont have cd burner on the laptop so would i be able to save it on to the harddrive and then transfer it using my home network to another computer with a cd burner and then take it from there?
thanks -
thanks so far
one question though, my laptop only has one parition, c:drive, could i save the ghost image to anohter hardddrive over a network or could i just use the cd burner of anohter computer over a network? in other words, could i run norton ghost from my laptop and when asked to create the bootable image cd use the cd burner from my other computer over my network through my router?
hope that makes sense, thanks again for the help
alright -
OR
is it possible to create a backup recovery disk of a harddrive from another computer over a network, router.
i mean install norton ghost on comp A. comp A is connected in a network sharing with comp B, from comp A you can see the entire hdd from comp B. with comp A, using norton ghost create a bootable recovery cd of the harddrive from comp B, then use that recovery cd to restore comp B, does that make sense?
thanks for any help
alright -
Yup! I do this on a regular basis with my laptop.Originally Posted by duffyr83
One of my desktop machines has the DVD burner, so I run Ghost 2003 on it AND the laptop, connect the two together with TCP/IP over my Linksys switch and create an image of my laptop drive on the desktop drive. Since Ghost does its thing in PC-DOS, you need to configure your network settings ahead of time.
Once that's done, I reboot the desktop and burn the Ghost image + *.exe from the Norton Ghost 2003 directory, to a bootable DVD using NERO.
If I ever have a problem, or want to restore the image, I boot off that DVD, run ghost.exe and walk away. 30mins later (8.4GB of compressed data), the image is restored.
Works like a charm
thanks, i'm going to buy norton ghost now and back up my laptop
thanks everybody for your replies
alright
Can't restore win7 backup image from server with win7 image restore.
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 14th Dec 2010, 18:56 -
Restore disk image on different operating system
By r3n4ud in forum ComputerReplies: 7Last Post: 1st Sep 2009, 09:44 -
How do I restore my Hard Disk Image?
By wiseant in forum ComputerReplies: 3Last Post: 2nd Oct 2008, 21:56 -
Creating / converting DVDs with Devede: Disk usage bar underestimates size!
By nicolaidenmark in forum LinuxReplies: 4Last Post: 22nd Aug 2008, 23:09 -
Question about how can Ghost (restore) avoid bad sectors on disk
By jimdagys in forum ComputerReplies: 4Last Post: 26th Apr 2008, 20:43
