hey i have a lite-on dvd +/- dvd burner and ive been using dvd x copy....it seems to begin reading dvds alot slower than usual. usually it would take about like 15 min to read each dvd, 15 min to burn, now all dvds are taking no less than 35 min to just read. i dont understand!!![]()
Newsflash:
DVD X Copy is killing from beyond the grave !
Seriously, I would examine perhaps any other programs running in the background ? Please don't tell me you're playing games while its working !If in doubt, Google it. -
i dont play games but AIM is running along with ati control panel and a virus protector in the quick bar---usually i just surf the web
please help! ive reinstalled all IDE drivers, shutdown all programs running, and my burner has still dropped significant speeds in just reading not burning
Make sure your dvd burner is set to DMA. I would suggest using DVD SHRINK to back up your dvds instead of DVD X COPY.
THERE'S a good thought right there!Originally Posted by budz
Has your IDE channel reverted back to PIO for some reason?
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
DVD Burner
By jason in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 16:02 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
