This is driving me crazy! Every time I tried to normally uninstall TMPGenc from the Add/Remove Programs control panel, the Install utility loaded up and promptly exited without any notice or warning. So I manually brute-force uninstalled it by deleting the TMPGENC folder and it's contents and then I deleted every reference to it in the registry.
Then I rebooted and tried to install the new version of TMPGenc, but it always fails with the following error messages:
It turns out that error 1603 means: "Error installing Windows Installer engine. A file which needs to be replaced may be held in use. Close all applications and try again."Error 1714 during install -- unable to remove old version
THEN:
"Feature transfer error
Error: -1603 Fatal error during installation
Consult Windows Install Help (msi.chm) or MSDN for more info"
Naturally, I tried exiting all applications and then re-installing, but I got the same error.
So then I tried installing it from Safe Mode (although I'm still having trouble getting into Safe Mode deliberately, see: https://www.videohelp.com/forum/viewtopic.php?t=214897), but I STILL got the same error!
What should I do? Thanks in advance for your help!
Results 1 to 9 of 9
Poor old work still uses NT4 (going XP v soon - makes my job easier), and we get these when NT has been patched in the wromg order, dodgy installs etc.. and the only fix we've found that works 100% is to splat the system and re-build it - I love Ghost.........
Unfortunately a reformat is pretty much the only way. -
Re-formatting strikes me as a highly over-dramatic "solution"! Re-installing Windows and all of my 700+ installed programs would take months! It is simply not an option.
What I need is someone who understands Installers who can help guide me to why TMPGenc thinks an older version is still installed even though it's not.
Please don't suggest re-formatting or re-installing Windows. There ARE better solutions, as described above. -
Do a search on the Microsoft for the errors and good luck....
Here you go.
http://support.microsoft.com/default.aspx?scid=kb;en-us;304888
Good Luck -
A typical easy trick is to simply re-install the program to get it properly loaded in the registry and install shield bases. Then go back through the "add and remove" function from control panel. If the file is corrupted, often uninstall cannot address it. It must be fixed first.
LRD -
Sorry, seems I did not read far enough. Looks like you tried my trick already.
LRD -
What you haven't done a ghost of your drive recently ?Originally Posted by newbee51
re-formatting is probably the best option because it will *definitely* fix this problem and any other problems you might be having. Your computer will be as new in terms of performance. It is also a good time to take stock of the programs you have on your PC - which ones you really need and which ones you haven't used in a while. I make a habit of reformatting my system drive every 12 months. Everything runs smoothly all of the time.
Basically, if you want to wait around for a bandaid solution, by all means do so.If in doubt, Google it.
I have downloaded malware 'Macrium Reflect' & I cant uninstall it :o(
By jacknscoob in forum Newbie / General discussionsReplies: 13Last Post: 28th Jan 2012, 22:35 -
Quicktime wont uninstall/install
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2009, 14:44 -
ImageMixer3 & MovieAlbum install both?
By zmartha in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2009, 23:47 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 14:43 -
Getting an error on install
By xduckster in forum ffmpegX general discussionReplies: 4Last Post: 3rd Sep 2007, 17:30
