  1. I have some flash videos that I would like to convert to avi or mpeg. Isd there a free program that can do this for me? I have searched but have't found anything yet. Thanks in advance
    Lisa, "Turn down the TV" "Honey if we didn't turn it down for the Cops, what chance do you have"-Homer Simpson
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    There's a guide on this site here. Do a google search for swf to avi and you'll find other programs that can perform the conversion too.
  3. Thank you, I 've searched Google and have only found programs that put watermarks on the end results. Thank you so much
  4. Ok I have a problem I have the saved flash file but when i try and load it into Quictime, but it says there is invalid date media the movie and cannot open. What is wrong?
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    No idea, dude. You might want to consider trying another method. One thing you can try is using Camstudio to record a portion of your screen while the swf is playing.
  6. Hi There,
    I think there is a program called Sothink you could try for doing that!
    Keep going till you get it right!!!
  7. Ok, Thanks
