  1. Hi,
    How or what can I use to extract the AC3 audio track from a VOB file on my karaoke dvd?
    try virtualdub-mpg
  3. Member adam's Avatar
    Sep 2000
    Use just about any dvd ripping software. Most have an option for stream processing which lets you choose the individual streams you want and whether you want to export as a program stream (vob) or as elementary streams (AC3 by itself for example.)
    I use DVD Decryptor for all of my ripping.
    If you do this to get the ac3 file from a dvd using decriptor or virtualdub-mpg and you want to play this clip with the corresponding video do you need to worry about the ac3 delay?
  5. Originally Posted by troyvcd1
    Demux using DVDdecrypter. Part of the naming convention of the output AC3 is the lag/lend time in ms. Let the tool complete the demuxing and it will rename the file with the delay.
    There is a reason why God gave us one mouth and two ears!!!
