Playing interlaced material on a computer monitor looks bad, as anyone knows. Deinterlacing works, but camcorder footage may still have problems because it often contains fast pans that still look rattling and blurry at 25 or 30 fps.
Trying to find a way to send full quality CD copies of my DV footage to friends, I remembers those '2 x fps' filters in TMPGenc. Maybe making a full frame of each field would do the job.
It does !
Basically, it's a progressive, double frame rate format, an element of some HDTV standards.
On a CPU 800 MHz or above, MPEG2 at double frame rate can be perfectly played, and file size does not have to increase significantly.
I've added some text about it to my page, as well as templates for TMPGenc.
Results 1 to 1 of 1
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 04:40 -
AutoGK : MPEG2 to Avi Frame Rate Problem
By Mokkori Chan in forum Video ConversionReplies: 6Last Post: 27th Feb 2009, 03:51 -
AVI playback shows frame rate and time code etc
By piledriver351 in forum Software PlayingReplies: 5Last Post: 26th Aug 2008, 02:42 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
