damn, if its under 4gbs it wont play, that sounds crazy. after my previous post i had downloaded nero 5.4. somethin somthing to use that xbox tick thing. i burned some files dvd shrink had placed onto my drive. i used dvd -RW. it didnt read in xbox. i put into my dvd rom drive and it dindt run as a dvd it ran as if it were a floppy disc. ya know just showing all the vobs n stuff. i clicked the xbox thing in the "UDF" option and in the "udf/iso mode" option. look at pick to see what i meant.Originally Posted by mastersmurfie
im going to ripp files with dvd decrypt next and send them straight into nero instead of usign dvd shrink's files next.
Results 31 to 35 of 35
Originally Posted by SnookayDCC
Well my Xbox has a Samsung drive and it seems to like Ricoh 4x disc ok.
Nero has an option to force Xbox compatibility mode. So they work on the xbox. So you have to use that option.
To back up Ninja Gaiden, you first need to network your xbox and pc, then use a prog. like xbox ripper to get the files to your pc. after you have the files-
Get rid of the japanese lang. movies(ones with the J at the end)
Use qwix to make an iso to burn
open up nero 6- close the wizard that pops up, hit recorder, burn image, and in about 5- 10 min you will have a working back up- dont forget that mod chip though.
But seriously there are better forums out there for this type of info.
Windows Media Center on Xbox 360 - how it works and codecs help!
By prankstare in forum Media Center PC / MediaCentersReplies: 6Last Post: 5th Feb 2011, 09:29 -
mkv2vob, works great for my PS3...not my Xbox 360?
By RalphMachio in forum Video ConversionReplies: 0Last Post: 14th Oct 2010, 08:43 -
Media Extender - Xbox 360 and HD Content
By BMT in forum Software PlayingReplies: 2Last Post: 8th Dec 2009, 17:01 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
Xbox 360 or PS3 as media server??
By Browncoat in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Dec 2008, 00:56
