Hi...I know i posted about Ulead workshop like..few hours ago..
hmm..since no one replied..and i got this wierd idea
it will be appreciated if anyone REPLY!!(sarcastically) just jk.. :P
hmm..since Ulead can't handle the bitrate or whateva the problem is
is it possible to just switch the vob file? after making the video_ts folder
with checking the complaint templete thing...
my englsih it bad..-_-;;i know...neways..any answers?
Firstly, no one will reply if they don't know the answer.
Secondly, I have no idea what your problem is. I cannot make it out from the sketchy details you provide. Please outline exactly what it is you are trying to do, the steps you are taking and the error messages (word for word) that you are getting along the way.If in doubt, Google it. -
Hee...^_^ well firstly
u did reply haha...which is a good thing hehe
and yes...sorry i'll provide the detail
the exact error msg is..
Title bitrate check:
Title name: < 01_pd >
The total bitrate (Video+Audio+Subtitle) of the above title is too high.
Please change the disc template or reduce the number of audio tracks.
Title name: < 02_pd >
Title name: < 03_pd >
and there is this other msg when i press the finish button
Overlapping subtitle(s) found in:
Title name: 01_pd
Stream 1 is overlapping
Stream 2 is overlapping
Title name: 02_pd
Title name: 03_pd
and the details of my files..
Video: 8300 kbs average, 9455 kbs max and min 0
audio: 3 tracks of 112kbs
subtite: 2 tracks
and what im trying to do is...burn this to a disc or put them into the
video_ts folder so i can burn them with other programs.
and if there is ANY way to burn this...with Ulead workshop 2.0
i'll be happy^^ -
Sorry I had to be so blunt
At least now someone has a much better idea of where you might be going wrong. The first error message is easily fixed. The combined bitrate of your video (9455) and your audio (3 x 112) and your subtitles is over the 9800 which is DVD max bitrate. Try re-encoding with a lower max video bitrate - say 9000. I would never have a min of 0 either - put it to about 3000.
I can't help with your subtitle errors.If in doubt, Google it. -
haha...thnx
hmm...well i used bitcalc
and it gave me 9455 value..-_-++
aw..the pain...T_T -
sorry but the problem is still there after encoding it to max 9000 kbs
and i found something more... when i load the m2v file from
Ulead DVD Workshop, it says max 9800kbs.
it doesn't matter what file i use, it always says 9800kbs max.??
nevermind..
i found out that EVeRYTHING was CCE's problem
i have to encode 6 divxes again..
THIs is 4th TIME!! T_T
it turned out that if i check 'dvd complaint' it always record 9800 as
maximum bitrate..BITE ME.. :P
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 21:51
