I will be moving to Ireland soon and have some DVD's (about 20) that I bought here and want to bring to Europe with me when I go.
I beleive that there is something about not being able to play because of the difference in TV's or something. None of thes are recent releases and I do not think that I will be breaking any laws. Any Ideas or suggestions would be welcome.
Thanks in advance
Results 1 to 9 of 9
most pal systems will be able to play ntsc
get a region free player is all ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I was not planing on it why? I was planning on buying a new 'puter and dvd over there, are you aware that there is a voltage difference?
no -- i mean stand aloneOriginally Posted by Airtaine"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
There is no voltage diff btween GB and Ireland
Just asking the dumb question first and getting it outta the way. I was not aware of a voltage difference. I would never have known about it had I not asked the question !
I foresee two options:
1. Buy a DVD Player that plays both PAL and NTSC and also plays region free or is able to be hacked to region free.
2. Copy your DVDs with something like DVDShrink which will make them region free. You will still have the PAL/NTSC issue though.
Either way, you're going to have to take them to Ireland with you to test if they work !If in doubt, Google it. -
I don't think I have found a player in UK that doesn't handle NTSC and PAL . Tvs are PAL only but the players convert on the fly to pal so no viewing issues.
You just need region free player for original non-region2 DVDs.
Just one thing you say your moving to Ireland but it doesn't say anywhere where you are moving from.
How we can bring a compressed movie in genuine condition
By nusratjaveid in forum Newbie / General discussionsReplies: 13Last Post: 20th Oct 2010, 22:49 -
Buying DVD HDD recorder in Ireland
By daithi_dearg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Mar 2009, 16:57 -
Best codec to bring Huffyuv down to size
By galneon in forum Video ConversionReplies: 7Last Post: 25th Feb 2008, 13:30 -
How to bring original subtitles into my project?
By lovejade in forum SubtitleReplies: 1Last Post: 28th Oct 2007, 03:17 -
Dixons - Northern Ireland
By kmelvin in forum DVB / IPTVReplies: 4Last Post: 28th May 2007, 10:11
