What File extensions are viewable in a dvd player that plays vcds?
let me change my question, what formats are viewable in a DVD player that reads VCDs.
Can you not find your DVD Player in the DVD plyer section on the left.
Your question cannot be answered , as DVD players play back whatever they are designed to playback. It depends on make and model.
OR if you have not yet got a DVD Player what is it you want it to play back ? -
I found it, im not sure though. THis is it.
https://www.videohelp.com/dvdplayers.php?DVDnameid=3677&Search=Search&#comments -
Definately don't assume anything . You've more chance of a big brand NOT being able to play VCDs.
I've just had a google and the only place I can even find that model is on ebay.
I may be assuming , but the reason you are in such a hurry is because that is where you are thinking of buying one from.
I think if you posted a topic asking 'Should I buy a Panasonic SA-HT95 from ebay?' you would get some very mixed responses.
If you want a DVD player that plays VideoCDs , at least find one that says it in the specs. -
Update - I found this :-
plays DVD-Video discs, DVD-Audio discs, CDs, audio CD-Rs & CD-RWs, and MP3 CDs
DVD CD and mp3 - That's It
Video file extensions cheat?
By stealedcircle in forum Newbie / General discussionsReplies: 9Last Post: 4th Feb 2012, 11:42 -
Is there 2 kinds of AVI extensions?
By jbitakis in forum Video ConversionReplies: 7Last Post: 24th Nov 2011, 11:32 -
New (?) files extensions
By Jomapil in forum ComputerReplies: 4Last Post: 10th Feb 2010, 12:40 -
seeing extensions in files
By vipertongn in forum ComputerReplies: 1Last Post: 28th Dec 2007, 05:42 -
How to change file extensions
By tweedledee in forum ComputerReplies: 23Last Post: 8th Jun 2007, 14:43
