Hmm..well the problem is...
everytime i try to make the dvd image, i get the message that
the total bitrate is too high.
i used 8300kbs for video VBR with the pulldown
3 audio tracks 112kbs
and 2 subtitle track
how do i burn this without rencoding?
To burn without re-encoding, adjust your Ulead DVD WORKSHOP 2.0 project settings to *match* the properties of your source clips.
For example, I sometimes work with MPEG-2 clips with the following properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Field Order A
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 8264 kbps)
LPCM Audio, 48 KHz, Stereo
I then adjust my Ulead DVD WORKSHOP 2.0 project settings to match.
I explain the steps on the Web page at the following link:
http://www.jonesgroup.net/dvdworkshoptwostepone.htm
Jerry Jones
Originally Posted by Yie_mi?
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 11:29 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 16:06
