ok, my bro wants to buy a cpu and is looking for a cheap but value for money dvd writer
we've got a pioneer DVD-RW DVR-105 and we kinda satisfied with it.
any advices for really good value for money?
looking for something around 200 bucks (or euros)
here's a database sort by ratings and 8x.
https://www.videohelp.com/dvdwriters.php?DVDname=&cdrs=&cdrws=&dvdrs=&dvdrws=&dvdprs=8&d...orderby=Rating
You in the US or Europe?
Will he be keeping the burner for awhile (over 9 months) or be moving on to a newer one by then? -
You need more than a cpu you need a whole computer.
Left column, dvd writers for comments as mentioned above.
Also, best prices are on the main page top tight corner, hit refresh & they should show up. -
yeah i meant a whole cpu, but im not native english...
thx for the database; i tried to use it but wasnt able to get good results, i might have done something wrong :P -
Well the highest rated burner was the NEC 2500A and ebuyer.com had it for 59 pounds. It does + and - and has a hacked firmware that also does bitsetting.
http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3...duct_uid=56658
If you want to take a chance on a burner that does all that and was third (but way way less buyers) down (its predecessor) and promises to do dual layer then you might also look at the BenQ DW822A.
Looking for advice on buying a new DVD recorder
By luvsufo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Feb 2011, 16:10 -
Buying DVD DL on Rima, need advice
By Thadius856 in forum MediaReplies: 1Last Post: 26th Jun 2008, 01:58 -
Need advice about buying a Dvd-R DL burner
By southrngntlmn1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 23rd Apr 2008, 13:12 -
Buying advice for portable DVD players?
By lordsmurf in forum Portable VideoReplies: 0Last Post: 12th Sep 2007, 10:58 -
key things to look for when buying a dvd writer
By zinc in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 11:50
