Using tmpg to convert
says in properties that its just an avi
so converted (encoded) it with combined audio and video as the results. using the wizard
started off as 780mb and ended up as one file of 4.08 gig
the author chooses the same file for the video and the audio but calls one mpeg one and the other mpeg two
right i then author it and tmpgen author makes two files one with a loads of video and audio file is empty.
desided to burn anyway because this is suposed to be combined vid and aud isnt it ...so i burn .......and i get no sound on the finished dvd .....what am i doing wrong.
another question is there any way you can view the results of your authoring without having to burn and waste a dvd
or can you view before authoring to make sure your (combined) encoded version has sound.
so i dont go wasting any more disks ........me thinks im going to have to get some re-writer discs to practice on ......any recomendations ....ones that work on most players etc.
all the best..mark
OK, first things first.
I'll start at the finish first - You can test your authored DVD in two ways - 1. Burn to a RW OR 2. Use DVD software such as Power DVD to view the contents before burning.
Starting from the start, it sound like you might have VBR audio in the AVI. The way around this is as follows:
Use VirtualDub. Open AVI. If the file has VBR audio a message box will pop up here. On Audio Menu, change to "Full Processing". Go to File > Save WAV. This will extract the audio from the file to an uncompressed WAV file. Use TMPGEnc and use the relevant template (DVD NTSC OR DVD PAL). Load the AVI as the video file, Load the WAV as the audio. This will create one MPEG-2 file for you. Check this file for the presence of audio. Author this file with TMPGEnc DVD Author and check the output for the presence of audio by either burning to a RW or by opening the files using Power DVD.If in doubt, Google it. -
I'm giving nerovision express ago with this one...it's doing it's job right now .it worked with other avi's ok,it has the plug-in... will use tmpgenc just for divx files seems to work ok with them ...non of this fuss and bother.
I like nero vision express... its so easy.....and it has always done a good job...and is easy to use ...far easier then tmpgenc and authors all in one go.
Think if they had a divx encoder plugin on nerovision then there would be no beating it...for someone who wants an easy life ........
THANKS very much for the advice JIM .
will follow it to the letter if Nero does not do the job.
until then all the best.......mark -
NERO MADE A TEMPORY FILE FOR THIS FILM OF 22 GIG ......
FILLED THE REMAINING SPACE ON MY HARD DRIVE!!!!
so did not get to carry out the writing
when i started the encoding it said it would need 3.31 gig on the 4.7 gig dvd.
whats going on guys
here is the error report........have deleted severall hundred lines of it
put xxxxxx were the name of the film is copirite issues blah blah blah
Process information:
Address Version Module name
0x00330000 2.0.0.4 C:\Program Files\Ahead\NeroVision\GCLib.dll
0x003B0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\GDIPainter.dll
0x003C0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\MMTools.dll
0x00400000 2.0.0.4 C:\Program Files\Ahead\NeroVision\NeroVision.exe
0x00510000 2.0.0.4 C:\Program Files\Ahead\NeroVision\AMCUIBase.dll
0x00610000 2.0.0.4 C:\Program Files\Ahead\NeroVision\GCCore.dll
0x00670000 2.0.0.4 C:\Program Files\Ahead\NeroVision\AMCDocBase.dll
0x00770000 2.0.0.4 C:\Program Files\Ahead\NeroVision\AMCDOM.dll
0x00EE0000 5.3.1.902 C:\WINDOWS\System32\D3D9.DLL
0x01080000 5.3.0.900 C:\WINDOWS\System32\d3d8thk.dll
0x01090000 1.0.0.0 C:\WINDOWS\System32\IMAGXPR5.DLL
0x010E0000 1.0.0.0 C:\WINDOWS\System32\IMAGX5.DLL
0x01170000 2.0.0.304 C:\WINDOWS\System32\PICN20.dll
0x011A0000 5.0.0.304 C:\WINDOWS\System32\imagr5.dll
0x022A0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\GCFX.DLL
0x02540000 0.0.0.0 C:\Program Files\Ahead\NeroVision\NeVideoFX.dll
0x02730000 0.0.0.0 C:\Program Files\Ahead\NeroVision\NeVideoFX.bitmaps
0x028E0000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\NeroAPI.DLL
0x033E0000 1.0.0.93 C:\Program Files\Ahead\NeroVision\NeroFiles\NeRSDB.dll
0x03450000 2.0.1.56 C:\Program Files\Ahead\NeroVision\NeroFiles\WNASPI32.Dll
0x037D0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\ExpressUI.dll
0x03AD0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\ExpressDoc.dll
0x03B00000 0.0.0.0 C:\Program Files\Ahead\NeroVision\GCHW.DLL
0x03B50000 6.5.1.900 C:\WINDOWS\System32\msdmo.dll
0x03C10000 2.0.0.4 C:\Program Files\Ahead\NeroVision\GCFilter.ax
0x03C60000 1.1.4.6 C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax
0x04500000 1.0.0.9 C:\Program Files\Common Files\Ahead\Lib\DriveLocker.dll
0x04950000 2.0.0.4 C:\Program Files\Ahead\NeroVision\DVDUI.DLL
0x049E0000 2.0.0.4 C:\Program Files\Ahead\NeroVision\DVDDoc.dll
0x04A30000 2.0.0.4 C:\Program Files\Ahead\NeroVision\DVDEngine.dll
0x04FD0000 0.0.0.0 C:\Program Files\Common Files\Ahead\DSFilter\NeroVideoProc.ax
0x05000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\CDROM.DLL
0x05140000 2.0.2600.1106 C:\WINDOWS\System32\msi.dll
0x05350000 0.0.6.0 C:\Program Files\MediaXW\MediaXW.dll
0x054E0000 1.0.0.0 C:\WINDOWS\System32\l3codeca.acm
0x055C0000 1.0.0.7 C:\Program Files\Common Files\Ahead\Lib\NeroCBUI.dll
0x056E0000 0.6.8.0 C:\WINDOWS\System32\ac3filter.ax
0x05770000 6.5.1.900 C:\WINDOWS\System32\qedit.dll
0x05A00000 0.0.0.0 C:\Program Files\Common Files\Ahead\DSFilter\NeroFormatConv.ax
0x06300000 1.0.0.2 C:\Program Files\Common Files\Ahead\DSFilter\NeAudioConv.ax
0x063E0000 4.0.4.0 C:\Program Files\3ivx\3ivx D4 4.0.4\3ivxDSDecoder.ax
0x06440000 4.0.4.0 C:\WINDOWS\System32\3ivx.dll
0x06710000 6.5.1.902 C:\WINDOWS\System32\qdvd.dll
0x081F0000 0.0.0.0 C:\Program Files\Common Files\Ahead\DSFilter\NeVDec.ax
0x10000000 5.9.9.5 C:\Program Files\Ahead\NeroVision\HDCC.dll
0x15000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\image.dll
0x19000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\MMC.DLL
0x1C000000 4.0.0.37 C:\Program Files\Ahead\InCD\incdshx.dll
0x1C200000 6.5.1.900 C:\WINDOWS\System32\qcap.dll
0x1C400000 1.5.0.50 C:\WINDOWS\System32\L3CODECX.AX
0x20000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\NeroErr.dll
0x21000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\neroscsi.dll
0x22000000 6.0.0.0 C:\Program Files\Ahead\NeroVision\NeroFiles\newtrf.dll
0x35500000 6.5.1.902 C:\WINDOWS\System32\QUARTZ.dll
0x35680000 6.5.1.902 C:\WINDOWS\System32\devenum.dll
0x51000000 5.3.0.900 C:\WINDOWS\System32\DDRAW.dll
0x51080000 5.3.0.900 C:\WINDOWS\System32\DSOUND.DLL
0x5AD70000 6.0.2800.1106 C:\WINDOWS\System32\UxTheme.dll
0x5C000000 5.3.1.902 C:\WINDOWS\System32\D3DIM700.DLL
0x5CAD0000 6.0.2800.1125 C:\WINDOWS\System32\shmedia.dll
0x5EDD0000 3.50.5014.0 C:\WINDOWS\System32\OLEPRO32.DLL
0x5EF80000 5.3.0.900 C:\WINDOWS\System32\KsUser.dll
0x60000000 1.5.4.36 C:\WINDOWS\System32\IJL15.dll
0x70A70000 6.0.2800.1400 C:\WINDOWS\system32\SHLWAPI.dll
0x70D00000 5.1.3101.0 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_65 95b64144ccf1df_1.0.10.0_x-ww_712befd8\gdiplus.dll
0x71500000 6.0.2800.1400 C:\WINDOWS\System32\browseui.dll
0x71700000 6.0.2800.1400 C:\WINDOWS\System32\shdocvw.dll
0x71950000 6.0.2800.1106 C:\WINDOWS\WinSxS\X86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.10.0_x-ww_f7fb5805\COMCTL32.dll
0x71AA0000 5.1.2600.0 C:\WINDOWS\System32\WS2HELP.dll
0x71AB0000 5.1.2600.1240 C:\WINDOWS\System32\WS2_32.dll
0x71C20000 5.1.2600.1106 C:\WINDOWS\System32\NETAPI32.dll
0x72D10000 5.1.2600.0 C:\WINDOWS\System32\msacm32.drv
0x72D20000 5.1.2600.0 C:\WINDOWS\System32\wdmaud.drv
0x73000000 5.1.2600.1106 C:\WINDOWS\System32\WINSPOOL.DRV
0x732E0000 5.1.2600.0 C:\WINDOWS\System32\RICHED32.DLL
0x73B50000 5.1.2600.1106 C:\WINDOWS\System32\AVIFIL32.dll
0x73BC0000 5.1.2600.0 C:\WINDOWS\System32\DCIMAN32.dll
0x73BD0000 5.1.2600.1106 C:\WINDOWS\System32\MSVFW32.dll
0x74D30000 5.1.2600.0 C:\WINDOWS\System32\oledlg.dll
0x74E30000 5.0.0.0 C:\WINDOWS\System32\RICHED20.dll
0x75A70000 5.1.2600.1106 C:\WINDOWS\system32\USERENV.dll
0x75F40000 5.1.2600.1106 C:\WINDOWS\system32\appHelp.dll
0x76380000 5.1.2600.1106 C:\WINDOWS\System32\MSIMG32.dll
0x763B0000 6.0.2800.1106 C:\WINDOWS\system32\comdlg32.dll
0x76600000 5.1.2600.0 C:\WINDOWS\System32\CSCDLL.dll
0x76620000 5.1.2600.1106 C:\WINDOWS\System32\cscui.dll
0x76670000 5.1.2600.1106 C:\WINDOWS\System32\setupapi.dll
0x76990000 5.1.2600.1106 C:\WINDOWS\System32\ntshrui.dll
0x76B20000 6.0.0.9435 C:\WINDOWS\System32\ATL.DLL
0x76B40000 5.1.2600.1106 C:\WINDOWS\System32\WINMM.dll
0x76FD0000 3.0.0.4414 C:\WINDOWS\System32\CLBCATQ.DLL
0x77050000 3.0.0.4414 C:\WINDOWS\System32\COMRes.dll
0x77120000 3.50.5016.0 C:\WINDOWS\system32\OLEAUT32.dll
0x771B0000 5.1.2600.1263 C:\WINDOWS\system32\ole32.dll
0x773D0000 6.0.2800.1233 C:\WINDOWS\system32\SHELL32.dll
0x77BD0000 5.1.2600.0 C:\WINDOWS\System32\midimap.dll
0x77BE0000 5.1.2600.0 C:\WINDOWS\System32\MSACM32.dll
0x77C00000 5.1.2600.0 C:\WINDOWS\system32\VERSION.dll
0x77C10000 6.1.8638.1106 C:\WINDOWS\system32\msvcrt.dll
0x77C70000 5.1.2600.1106 C:\WINDOWS\system32\GDI32.dll
0x77D40000 5.1.2600.1255 C:\WINDOWS\system32\USER32.dll
0x77DD0000 5.1.2600.1106 C:\WINDOWS\system32\ADVAPI32.dll
0x77E60000 5.1.2600.1106 C:\WINDOWS\system32\kernel32.dll
0x77F50000 5.1.2600.1217 C:\WINDOWS\System32\ntdll.dll
0x78000000 5.1.2600.1254 C:\WINDOWS\system32\RPCRT4.dll
0x780C0000 6.0.8972.0 C:\Program Files\Ahead\NeroVision\MSVCP60.dll
Properties of your project:
Aspect ratio: 4:3
Video mode: PAL
Quality: Standard play (5073 kbps)
Used disc space: 3.31 GB
Your project contains the following:
Number of titles: 1
1. xxxxxxxxxxxx ( DVD Rip ) (Video Title, 83:51 minutes)
Number of menus: 1
- Menu for xxxxxxxxxxxxx - 2002 ( DVD Rip ) (1 page)***BEGIN: DVDSessionBase - RegisterApplicationService
...Application service registered...
***END: DVDSessionBase - RegisterApplicationService
***BEGIN: DVDSessionBase - RegisterCallback
...Session callback registered...
***END: DVDSessionBase - RegisterCallback
***BEGIN: DVDVideoSessionImpl - Prepare
***BEGIN: _DVDVideo - Prepare
...VTS_Ns = 1...
***BEGIN: _DVDBase - Prepare VMG
...VMGM_VOBS_exist = true...
***BEGIN: _VOBS - Process Create
***BEGIN: _VOBS - Process VOB
***BEGIN: dvd_eng_nero_conversion_manager - load
...Media Converter interface version = 0x114...
***END: dvd_eng_nero_conversion_manager - load
***BEGIN: _VOBS - AnalyzeConverterInput
...Stream 0 is 'Video'
...Stream 1 is 'System/Stream'
***END: _VOBS - AnalyzeConverterInput
...estimating VOB size
...estimated VOB size is 425,984 Byte.
...estimating VOB conversion time
...estimated VOB conversion time is 1 sec
***END: _VOBS - Process VOB
***END: _VOBS - Process Create
***END: _DVDBase - Prepare VMG
***BEGIN: _DVDBase - Prepare VTS
...VTSN = 1
...VTSM_VOBS_exist = false...
...Stream 1 is 'Audio'
...estimated VOB size is 3,550,904,320 Byte.
...estimated VOB conversion time is 1 hour 42 min 15 sec
***END: _DVDBase - Prepare VTS
***BEGIN: _DVDVideo - Prepare OtherFiles
***END: _DVDVideo - Prepare OtherFiles
...estimated size (overall) = 3.31 GB
...estimated time (overall) = 1 hour 42 min 16 sec
***END: DVDVideoSessionImpl - Prepare
***BEGIN: DVDVideoSessionImpl - GetDiscContent
***BEGIN: _DVDBase - Create VTS
...VTSN = 1
...New VOB 1
...New CELL 1
...VOB1 CELL1 VOBU0 VOBU_S_PTM 26685 VOBU_E_PTM 73485 (29)
"""""""""""these cells go on for severall hundred then
ERROR:
cause: 58 (disk_full)
source: _VOBS
description: There is not enough space on the disk.
DumpExceptionInformation(): Caught SEH Exception 0xe06d7363 during encoding
DumpExceptionInformation(): Exception was raised from C:\WINDOWS\system32\kernel32.dll at RVA 0x00013887
ERROR:
cause: 128 (nmc_processing_exception)
source: _VOBS:
oGuardedProcessing ()
description: Exception during encoding
***END: _DVDBase - Create VTS
DVDENGINE exception caught.
***END: DVDVideoSessionImpl - GetDiscContent
...Session callback unregistered...
any ideas what is going on.
all the best.mark
DVD Video made with PiTiVi and DeVeDe -- no sound. How do I proceed?
By VanillaMozilla in forum EditingReplies: 8Last Post: 7th Mar 2011, 12:02 -
Add chapters (at least) to already made DVD
By tge101 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 14:16 -
Any DVD or BR burners made in Japan?
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Dec 2008, 14:38 -
No sound on dvd burned with convertx2dvd made from ratdvd
By maureensullivan in forum Newbie / General discussionsReplies: 10Last Post: 5th Aug 2007, 19:41 -
Verbatim DVD+R DL - Made In India?
By zippy2k2 in forum MediaReplies: 27Last Post: 2nd Aug 2007, 12:56
