  1. Member flameout's Avatar
    Feb 2004
    Pittsburgh
    I did a search, but didn't find the answer, so I hope it's ok to post my question here. I downloaded the demo of Pinnacle Studio 9 to play around with it, but I must be doing something wrong when making menu's
    I captured my video (.avi file) and wanted to add a menu that I can select chapters from when played in my DVD player. I thought I had it, but when I burned to dvd (converted to mpeg-2 using TMPGEnc) the menu was there, but it just played right thru like a frame of video would, about 20 seconds or so, and I couldn't make any selections.
    My video has about 160 'scenes', is about 70 minutes long, and I added a menu with 6 chapters, but I can't select the chapters after I burn to DVD. I added the menu as my very first scene, right at the begining of my video
    I'm thinking of buying the program if I can get some of this stuff to work. It looks like a nice pgm I'm also curious as to how well the MPEG-2 encoding works, since it's not activated in the demo.
  2. Member flameout's Avatar
    Feb 2004
    Pittsburgh
    I did find those threads earlier, and actually used the one step by step. I'm able to make my menus, and they work find in demo of Studio 9, but if I burn to VCD, or make .avi file and then encode into mpeg-2 using TMPGEnc, then burn to dvd, the menus don't work from my DVD player. I'll keep trying. I'm sure I'm missing a step somewhere. I can't see them offering a demo of a program crippled so much that you can actually use it.
    I did see that Newegg has Studio 9 for $80, so I may just buy it and hope for the best
  3. Originally Posted by flameout
    1. I have no idea how menu works on VCD only DVD.
    2. When you make AVI you don't make MENU. Menu is part of DVD Authoring proces.
  4. Member flameout's Avatar
    Feb 2004
    Pittsburgh
    I went ahead and ordered Pinnacle's Studio 9, even though I didn't have any luck with the demo. I'm hoping that once I can do the MPEG-2 encoding right from Studio 9, the menu/chapters will work for me
