I have a Panansonic DV camera. Using the firewire and DV-AVI output option at the highest setting, 1 hour of video that I shot turned into 14 GB AVI file.Is that normal? Or is there some setting I need to change? Any ideas? [/u]
Yeah, it's sounds normal. Then you should convert to something like xvid using virtual dub and it will reduce the file size by something like 80% or so.
Originally Posted by nikkoforever
I transfer with powervcr to mpeg 2, which is dvd compliant, and then use TMPG author to burn dvd. It depends how fussy you are about quality.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 20:27 -
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 21:40 -
AVI files make DVD huge
By dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 19:09 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
Huge avi files in Virtual Mod
By KayAt in forum Newbie / General discussionsReplies: 3Last Post: 25th Oct 2007, 19:08
