Howdy,
I'm thinking that I'm starving a little as I'm using WinXP, P4,1.8Ghz with 256MDDR. I'm not looking for overkill or anything, just wondering what would be a good fit for encoding. After reading some of the posts it looks like the processor is going to be pinned regardless of your speed so I guess that's not an issue I have anymore. But I am wondering if I can multi-task while encoding or other heavy CPU action or should I just let the 1 program hog all the goods.
I'm using Ulead Video Studio 7 for most of my needs
Thanks,
Max
I would go to 512MB. You may not see much improvement in encoding speed, but it should improve multitasking. Beyond 512MB, the gains are less.
Movie Studio HD PLatinum adequate after Vegas 7 ?
By Prieur in forum EditingReplies: 3Last Post: 25th Feb 2011, 11:38 -
Super AntiSpyware Adequate Protection?
By wulf109 in forum ComputerReplies: 12Last Post: 9th Dec 2010, 00:37 -
RAM usage drops drastically after encoding
By Moontrash in forum ComputerReplies: 2Last Post: 2nd Dec 2010, 22:16 -
What Laptop is adequate for editing with Hauppauge HD PVR?
By Quivox in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2010, 18:26 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2009, 19:07
