hi,
this will probably have been asked loads of times and there is loads of different topics to choose from but it'll take me ages to find what I want. So i'm wondering if someone can help me out.
I have a few .avi files that are around 400mb-700mb and I am wanting to put them onto a 700mb cd so I can watch them on my dvd player. Can someone please tell me the programs that I need and tell me how to do it.
all help is much appreciated.
thanks,
Jon Cooper
If your DVD Player will play VCD then you could make an XVCD . You can put a film of whatever length you want on one cd-r and play it on a dvd player as long as it will play xvcd.
You also might want to look into getting a DVD player that plays mpeg-4(Divx/Xvid). That way you won't have to do any re-encoding.
Hi Jon,
I am having the same issue as you (avi to vcd/svcd, to play on my dvd player) So far I learned that you have to convert the avi to mpeg-1, then you can burn it to a blank cd-r disk with a cd-writer. This is now called a VCD.
I downloaded "Xvideo converter" free trial software to turn the avi to mpeg-1, and when all done, it did not play on my dvd player. Maybe some of this info. might be helpful to you.
If you figure out a solution please post it.
Volt48 -
No it is'nt, and this may explain the problem you are having. Simply burning an mpeg1 (vcd compliant) to a CDR does not make it a VCD. It has to be authored to become a VCD. Se the authoring section.Originally Posted by volt48
Read this then check out these guides.Originally Posted by supercoop"Art is making something out of nothing and selling it." - Frank Zappa
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 11:09 -
Need help burning a 700mb file onto a disc to be played on DVD player
By chaoscreater in forum Video ConversionReplies: 7Last Post: 11th Jul 2008, 05:20 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26 -
will a avi data disc play in a divx player?
By nobbyiscool in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 15:23
