  1. just found a program (speedfan) which tells you your case and hard drive temps
    http://www.almico.com/speedfan.php
    trying to determine if i need new fans or if my stats are fine
    interested in what other peoples are try to estimate your room temp and describe what the pc has been doing as well (temp is going to be higher if you have been video processing as the processor will have been at 100% load for quite a while)
    heres mine
    room temp 15c
    pc been on for about 24 hours as the router been watching vids and downloading
    will post another later when video processing
  2. Those temperatures all seem to be in order. What do each of them mean, though - is one your CPU temperature? If so, you're fine.
    My motherboard temperature is 32 deg C, I can't get a case temp on my machine I don't think.
    Cobra
