I have a NEC 1300A, firmware 1.0a. I keep getting a read error. It states tha the blank media I insert has a file already on it(tried it with several discs - error always the same). Has anyone else had this? I would appreciate any help before I return the burner.
Also, what is DMA? Should this be enabled?
Thanks.
I can only answer the question about DMA. It is Direct Memory Access
Yes, you should enable it if it wasn't automatically enabled when you installed your burner. It should allow your burner to keep up with the speed of your HD better. -
Thanks. I now see that I can't have DMA.
Amazingly, I formatted the PC and the DVD burner works as normal. Very strange cos I installed it on another machine and had the same error.
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 22:45 -
AVStoDvd Help, urgent
By DaneClark in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2010, 21:22 -
Software help, URGENT
By ianbeddow in forum EditingReplies: 4Last Post: 6th Aug 2010, 05:23 -
messenger urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 1st Jun 2009, 10:39 -
Urgent computer help
By Seasonal in forum ComputerReplies: 24Last Post: 23rd Jul 2008, 03:49
