  1. Member chongo's Avatar
    Mar 2004
    Southeast, PA
    I am trying to convert some cartoons to DVD. But some the VHS is in poor quality. Is there any way I can
    a). fix the audio levels (some episodes were recorded with the audio levels very low, others were recorded with high audio levels).
    b). fix the color (the colors aren't solid within the objects, there are bars of yellow and orange inside something that is supposed to be just yellow).
  2. I would suggest reading Lordsmurf's website as he has lots of experience capturing cartoons/anime.
    http://www.digitalfaq.com/
    No, I'm from Iowa. I only work in outer space.
  3. Member DVWannaB's Avatar
    Dec 2001
    Not sure if the lordsmurf site gives you what you are looking for in total. But here below is a thread from the capture forum on this site. It deals with very bad vhs tapes:
    https://www.videohelp.com/forum/viewtopic.php?t=211936&highlight=vhs+tape
