Ok, this is my problem. In TmpGenc, when I reencode a 50 minute avi file, then in project wizard, it says that it will not fit on the disīk and that it's 167 minutes long. Is that caused by the quality? Or why at all?
insane scientist
Wow...this is wierd, I just tried again and it showed the right legth and also that it will fit on to the cd. Also, I think I diden't use a separate audio file before, like I did this time, cauld that have caused it?
insane scientist -
your avi file probably had vbr audio which can screw things up. you fixed it by seperating the audio from the video then encoding. always seperate the audio from the video before encoding a divx or xvid avi file.
Donadagohvi (Cherokee for "Until we meet again") -
Thanks a lot, that really cleared things up!Originally Posted by freebird73717insane scientist
AVI file length
By RonNYC in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2012, 18:47 -
What is the 120 minutes DVD length based on ?
By davexnet in forum Newbie / General discussionsReplies: 7Last Post: 9th May 2010, 22:11 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 12:41 -
TMPGEnc Issues with length of movie?
By doctorgonzo in forum Video ConversionReplies: 1Last Post: 11th Apr 2009, 11:30 -
Does WinDV transfer a maximum segment length of 19 minutes, 6 seconds?
By VMiller in forum Capturing and VCRReplies: 5Last Post: 13th Jul 2007, 22:55
